10-03-2020
16:53
17:25
LizzyFitbit
10-03-2020
16:53
17:25
LizzyFitbit
I've had this fitbit less than a week, and have been swimming with it 3 times. Every time I tell it I'm swimming it goes into waterlock - great - but when I stop swimming I can never get it OUT of water lock. The screen won't even show up. AND it never sends the workout to the dashboard so I can see it - it's like it just disappears and I end up having to log it manually anyway. What is the point of having swim as an exercise to track if it won't track it. Because I swim is the ONLY reason I got this one.....help - I'd really like it to work properly - how do I get it to record the exercise, and how do I get it to come back from water lock?
08-25-2021 10:58
08-25-2021 10:58
Yay it works! Thank you.
09-03-2021 23:09
09-03-2021 23:09
This worked for me also. A simple fix really, thank goodness.
09-07-2021 12:28
09-07-2021 12:28
I tried tapping and double tapping to no avail. I finally put it on the charger for a little bit, took it off, and then the double tap worked.
09-17-2021 17:04
09-17-2021 17:04
I was just chatting with online help for over 90 minutes about this with no resolution. I also tried rebooting and deleting and reinstalling to no avail. I have been a Fitbit user for years and have never had issues like this and I have only had it 1 day! I am returning it.
10-26-2021 07:03
10-26-2021 07:03
You are a genius! I've had constant problem with this since I've gotten the thing. Works soooo much better than changing the clock face!!!
10-28-2021 22:25
10-28-2021 22:25
I have the same problem with the water lock. I've tapped the screen twice and it is frozen. It does nothing.
10-29-2021 05:47
10-29-2021 05:47
10-30-2021 01:17
10-30-2021 01:17
10-31-2021 22:18
10-31-2021 22:18
Tap the sides hard to unlock It works
12-04-2021 18:27
12-04-2021 18:27
The only way I can get out of water lock is to use the app to change the watch face screen. When it sends the update, it lets me back in.
01-05-2022 12:41
01-05-2022 12:41
This reply of yours seems to miss the product users point…. I think we understand what the feature does, but we are reporting that the PRODUCT is FAULTY! mine also gets stuck in water lock… i have the same issue even putting it into water lock mode, a simple fix IF fitbit would actually listen to us users would be to add a feature to the app allowing us to put our Inspire 2’s in and out of water lock mode
01-05-2022 19:30
01-05-2022 19:30
01-07-2022 13:33
01-07-2022 13:33
Yes, thank you. This totally worked for me. Now to figure out how to deactivate the water lock completely!
01-16-2022 15:48
01-16-2022 15:48
Hi everybody.
Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out and for trying the suggested in this thread.
If this doesn't help, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
02-14-2022 10:58
02-14-2022 10:58
This is not helpful, and a bit insulting to this if us who can read instructions. Mine is the same problem as the original poster. Frustrating.
02-21-2022 21:22
02-21-2022 21:22
I had the same problem but for me it works as long as the screen is facing upwards. Double tapping doesn’t work if the screen is facing any direction but up for me. Hope this helps
02-26-2022 20:27
02-26-2022 20:27
This is the only thing that worked! Thank you!!
02-28-2022 07:36
02-28-2022 07:36
Not easy to do when you are in the swimming pool wanting to time your swim.
03-01-2022 09:54
03-01-2022 09:54
Double tapping does not work very often. Very frustrating.
04-16-2022 07:12
04-16-2022 07:12
changing the clock face in the app worked perfectly
