Inspire 2 won't connect to my phone's Bluetooth
My inspire 2 is not pairing to Bluetooth
Moderator Edit: Clarified subject and updated label
1 REPLY 1
Hi there, @Gisell. Thanks for stopping by in the Fitbit Community Forums and bringing this to my attention. I will do my best to help you with the syncing issues you're experiencing with your Charge 2.
If you haven't done so yet, I'd recommend following the tips and recommendations provided below:
  • Unpair your Fitbit device from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Fitbit device.
  • If there is no connection, restart your Fitbit device.
  • Once your Fitbit device is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Inspire 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
