Inspire 2 won't pair anymore
Since the last update, my inspire 2 is not able to pair anymore. Tried everything... The app finds the inspire, i am able to enter the 4 digit code but then a cross is displayed in the inspire and setup is aborted... It always worked fine until some days now...
5 REPLIES 5
Hello @Compie
When you get the red X after entering the code that’s usually happens because you didn’t unpair the Inspire 2 before performing a factory reset. It sounds like you might have done a factory reset first. Usually you should unpair your Inspire 2, then unpair from Bluetooth and then perform the factory reset.
Let’s see if we can try to set you up as a new device. You won’t lose any of your previous data. The only data that will be lost is anything that occurred after your last successful sync.
First make sure you are using the latest Fitbit App version and your phone is also updated. Now let’s unpair your Inspire 2 from the Fitbit App. Tap your profile picture then scroll down and tap Inspire 2 then scroll down and tap Remove This Inspire 2. Next sign out of the Fitbit App. Now go to the Bluetooth settings of your phone and look for your Inspire 2 in the list of connected devices and remove it. If your on an iOS device tap Inspire 2 then tap forget this device. If your on an Android device tap it and then tap unpair. (If your inspire 2 is not showing at all no worries just go to the next step) Next turn your Bluetooth off then shut down your phone for 1-2 mins. Now restart your phone, turn Bluetooth back on then log back into the Fitbit App. Tap your profile picture then scroll down and tap Set Up A Device. Pick Inspire 2 from the list of trackers then follow the onscreen instructions.
😃 I hope this provides you with the best answer and gets you back up and running again. Please come back and let me know how it goes.
Thank you but unfortunately this did not work. Before, the device could even not be seen. After pressing 10sec the inspire did a reset, removed the bluetooth from android, reinstalled the app and now it can find the device, i can enter the 4 digits code but then it hangs... Perhaps a factory reset is the answer... Is this the same as pressing 10sec the device?
Hello again @Compie
I’m only aware of how to do a factory reset directly from the Inspire 2. You have to go to your settings in the Inspire 2 to clear the user data. if your screen is just showing the red x it won’t be possible to go that route. I really think your best bet in this situation is to contact fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US You can call them directly. Their number is provided on the link I put here.
I’m very hopeful that they will be able to sort this out for you.
Many thx, clearing data on the device solved the problem. It paired like a charm.
That’s fantastic @Compie! 😃 I’m super happy that worked for you! Please consider marking my previous post as “best answer” about clearing data. Doing so really helps others experiencing the same issue find answers quickly. I’d appreciate it. I’m happy your up and running…enjoy the rest of your day and as always Happy Stepping!
