06-01-2022
18:54
22:22
06-01-2022
18:54
22:22
My Inspire 2 only will show the clock face, won’t scroll up or down, and when the sides are pressed it will only go to options for water lock, do not disturb, etc.. It will not switch off or reboot. Hold the sides for 5 seconds and nothing happens.
It syncs to the app with all the usual data but the swiping will not work.
06-02-2022 01:40
06-02-2022 01:40
Hi @Mcon83 I was going to suggest restarting,which usually solves this! But instead you will need to contact Fitbit Support
Helen | Western Australia
