08-02-2022
08:09
22:14
08-02-2022
08:09
22:14
Inspire 2 is no longer keeping accurate time. Can the time be reset/fixed?
08-02-2022 08:59 - edited 06-20-2023 08:22
Hi there, @ljnonna. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Inspire 2.
As @JohnnyRow has mentioned, your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If your Inspire 2 is no longer paired, please set it up by following these steps How do I set up my Fitbit device?
Also, note that the time on your Fitbit Inspire 2 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Inspire 2 is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
08-02-2022 08:26
08-02-2022 08:26
Only by syncing.
