08-07-2022
11:57
22:11
08-07-2022
11:57
22:11
I cannot get the right time on my watch
08-09-2022 00:10
08-09-2022 00:10
If you can get the syncing working again then the time and other issues may sort themselves out.
The usual things I try when I get syncing issues are:
If those ideas don't work for you then it’s probably best to contact customer support via: contact.fitbit.com and if they can't fix it then they can process your warranty claim.
08-08-2022 01:05
08-08-2022 01:05
You can't manually set the time, but it should reset itself whenever it syncs to your phone based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
08-08-2022 14:20
08-08-2022 14:20
08-09-2022 00:10
08-09-2022 00:10
08-09-2022 06:59
08-09-2022 06:59
