01-22-2023
08:00
09:07
01-22-2023
08:00
09:07
My clock is wrong. Not just the hours, the minutes are off too. I tried rebooting and syncing but it won't sync.
01-23-2023 09:09
01-23-2023 09:09
Hi there, @Apr991. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Inspire 2. @NellyG Thank you so much for your help.
Your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If by any chance you are running into syncing issues, see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
Also, note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
In addition, please make sure that your Inspire 2 is up-to-date. For more information, see How do I update my Fitbit device?
See you around.
Best Answer01-23-2023 01:15
01-23-2023 01:15
Hi @Apr991 Try THIS Help Article on syncing problems
Helen | Western Australia
01-23-2023 09:09
01-23-2023 09:09
See you around.
