09-17-2023
06:16
08:54
09-17-2023
06:16
08:54
My Huwaei phone stopped synching on August 29th with my Inspire 2. It had been fine up until then. Since then I seem to have spent hours following instructions off the internet & on here to try & remedy this. I wouldn't say I was brilliantly tech savvy but I have - Uninstall/reinstalled app , checking the notifications, bluetooth etc. I have updated the OS on my phone. I have almost lost the will to live at times.
I now use pen & paper to record my daily steps at bedtime. I am in my 70s & bitterly regret your decision to stop it from being usable on my laptop which was ideal for me. I much prefer to see things on a larger screen & resent 'having' to use my phone.
I will obviously try any other suggestions. It's a shame as I thought the fitbit (which I've had for a few years) was great. Apologies for moaning but writing it down has at least made me feel a bit better!
09-19-2023 09:14 - edited 09-19-2023 09:18
Hi there, @hullsaddler. Welcome to the Fitbit Community Forums. Thanks for taking the time to troubleshoot the issue with your Inspire 2 before reaching out. We‘re taking your comments and sentiments in regards to our products and services into consideration.
In addition to the steps you've done so far, I'd suggest trying the following in the order listed:
With the steps above, what I want you to do is to pair your Inspire 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Once you manage to sync your Inspire 2, the time should be corrected. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
09-19-2023 11:20
09-19-2023 11:20
09-20-2023 04:46
09-20-2023 04:46
@hullsaddler Sure thing! I'll be around if you need further help.
09-20-2023 10:45
09-20-2023 10:45
