Inspire 2 won't track my sleep stages
My new inspire 2 is not consistently tracking my sleep, missed two days in a row randomly even though I am wearing it.
Update: *misses, had happened on a few occasions
2 REPLIES 2
Hi there, @Bsthompson. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Inspire 2.
Please check the following scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep with my Fitbit device?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
For more information, see What should I know about Fitbit sleep stages?
Hope this helps.
I think this is more of an issue that what the "normal" issues are, which you gave tips for. My Fitbit has been tracking my sleep every night until this last week. I have not changed the location of my fitbit on my wrist. In fact, two days it showed the sleep pattern and score but two or three days later, those numbers are no longer showed up, even though they had been there previously.  I checked the app and it said I was "up to date" so no new download needed. However, when I uninstalled the app, at the recommendation of the "help" I can no longer download the FitBit App from Google Play store for Android phone. It says the app is not compatible with my phone. So now I have NO app on my phone. I am reallllyyyy ticked this morning, as I am having definite sleep/heart issues and we have been monitoring my sleep pattern carefully!
