08-02-2023
17:55
09:01
08-02-2023
17:55
09:01
I recieved a text and looked at my Inspire 2, but it wouldn't scroll down to see it all.
I pressed the side buttons to return to the main screen and realized it wasn't responding to any swipes or taps.
I looked up how to reset and followed the steps. Got the smiley face, and now nothing.
If I reset again the smiley face appears but the clock never shows up. I tried changing the clock face and I can see the install progress bar on my tracker, but again the clock won't appear.
08-04-2023 05:50
08-04-2023 05:50
Hi @JasonDeath It sounds as if your Inspire 2 has died. You have tried everything that might help. Contact Fitbit Support and see if they are able to help.
Helen | Western Australia
08-04-2023 09:28
08-04-2023 09:28
From the amount of people reporting the exact same issue, it sounds to me it's a software issue on fitbits end.
Everything still works. The screen still shows when I reset (smiley face) and when I switch the clock screen (progress bar).
The only issue is the clock face not showing up like it's been deactivated or blocked.
My Inspire HR is still going strong after 4+years (gave it to a family member). The Inspire 2 has had to be replaced and now this.
