12-17-2020
15:40
10:08
AlejandraFitbit
12-17-2020
15:40
10:08
AlejandraFitbit
I am getting some notifications on my Inspire BUT the Fitbit Inspire 2 doesn't vibrate.. no vibration for emails, messages, or phone calls... as far as I can tell everything is turned on.. getting frustrated up this device.. help please
12-30-2020 06:52
12-30-2020 06:52
@kastbrown — check to make sure that DND and Sleep are off (the icon is not illuminated). Both of those options will stop the Inspire 2 from vibrating. DND is particularly easy to turn on by accident because it is the first option up when you press and hold the side buttons. Then if you tap the screen you will toggle from off to on, or vice versa.
Scott | Baltimore MD
12-18-2020 10:10
12-18-2020 10:10
It's great to see you around, @TedJL.
I understand how are you feeling. If your tracker isn't vibrating, I recommend restarting the unit by following the instructions provided in the help article: How do I restart my Fitbit device?.
Let me know the outcome.
12-30-2020 05:53
12-30-2020 05:53
I am having the same problem with my Fitbit Inspire 2. It will not vibrate for phone calls, texts, etc. I am beyond frustrated. I had the Alta HR for years with no problem and got the Inspire 2 for Christmas. So far not excited about it. Ready to go back to my old one unless someone can tell me what I am doing wrong or what needs to be done.
12-30-2020 06:52
12-30-2020 06:52
12-30-2020 06:57
12-30-2020 06:57
Perfect! Thanks so much. That is what is was. It is working now.
12-30-2020 08:11
12-30-2020 08:11
Awesome. Glad it helped.
12-31-2020
10:14
05:18
12-31-2020
10:14
05:18
It's great to see you here, @kastbrown and @Baltoscott, I appreciate the help.
I am glad to see here that the instructions provided by our friend worked and that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
05-24-2021 17:54
05-24-2021 17:54
The inspire 2 isn't listed there. Mine is not vibrating for anything other than meeting 150/300/450 zone mins and burning 2300+ cals per day. All other vibrations have stopped though previously worked when moving into fat burn/cardio and also the hourly step reminders. How do I fix this?
05-25-2021 12:00
05-25-2021 12:00
@jannabug — try restarting it.
05-25-2021 16:38
05-25-2021 16:38
05-25-2021 19:23
05-25-2021 19:23
I have done all the suggestions to get notifications from my phone including reinstalling the app, turning everything off then on, checking the dnd and sleep settings, restarting the Fitbit... multiple times. Still no text or call notifications but I did get one from the airline I was traveling on a couple of days ago. PLEASE come up with a different solution to try!
05-25-2021 21:53
05-25-2021 21:53
05-26-2021 06:15
05-26-2021 06:15
@jannabug @Adkdeb -- DND and Sleep mode seem to be the most common reason users aren't getting notifications on the inspire 2, because they are so easy to turn on for this model. But I see you've checked that. Another common issue .... check to see that you don't have the device in 'clip mode.' See page 14 of the manual. That mode, meant to be used when you have your fitbit in your pocket or in a clip on your waist band, turns off a number of notifications. The manual mentions auto exercise tracking, active zone minutes, and heart rate tracking. It is also possible to turn off zone notifications on your phone.
For other notifications issues, check out the steps on this page.
Hope that helps.
06-25-2021 14:57
06-25-2021 14:57
Thank you!
So obvious now and yet your post is the only one I can see that mentions that fix!
07-23-2021 10:18
07-23-2021 10:18
What is DND?
07-23-2021
19:07
05:18
07-23-2021
19:07
05:18
Welcome to the Fitbit Community, @VeraJ76.
Thank you for joining the thread and sharing your concern. I would like to advise that DND means "Do not disturb" and this setting can be found in quick settings on your device. Please find more information about your device's display in How do I navigate my Fitbit device?
Hope this helps.
11-27-2021 13:28
11-27-2021 13:28
So disappointed in this unit. It could not be less intuitive. And i turn off dnd and it turns itself back on without me even touching it and i’m missing important messages as a consequence. I’m not doing it accidentally either. I am literally not touching it. Buzzes for first call then switches itself on. Why can’t this be controlled from the app? It would be a lot easier. I’ve gone from being really happy with my inspire hr to just plain annoyed. Really quite sad about it. Everything is so hard to navigate.
01-08-2022 02:45
01-08-2022 02:45
Thank you so much for your support, it worked, my fitbit now fribrates and I get messages
01-10-2022 06:37
01-10-2022 06:37
Did you have any luck finding a solution? I can only reset my device so many times!
Thanks,
01-10-2022 07:39
01-10-2022 07:39
OMG - THANK YOU SO MUCH - I was getting so frustrated but your suggestions worked perfectly!
