12-17-2020
15:40
21:20
EstuardoFitbit
12-17-2020
15:40
21:20
EstuardoFitbit
I am getting some notifications on my Inspire BUT the Fitbit Inspire 2 doesn't vibrate.. no vibration for emails, messages, or phone calls... as far as I can tell everything is turned on.. getting frustrated up this device.. help please
01-10-2022
14:02
23:20
YojanaFitbit
01-10-2022
14:02
23:20
YojanaFitbit
Yes, turn off DND and Sleep mode in settings.
Helga O
Moderator Edit: Personal info removed
01-10-2022 16:26
01-10-2022 16:26
01-14-2022
11:22
23:23
YojanaFitbit
01-14-2022
11:22
23:23
YojanaFitbit
Nope ... I still have to reset my device and delete and reinstall the app
regularly. And then my device still randomly stops/starts vibrating without
warning.
Moderator Edit: Word choice
01-14-2022 13:36
01-14-2022 13:36
01-14-2022 23:22
01-14-2022 23:22
Hi everybody.
Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 2 before reaching out and for trying the suggested here.
If the above doesn't work, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
01-15-2022 02:30
01-15-2022 02:30
It all works for me now, since I turned off my DND & my Sleep mode off
It vibrates when I get a message or a phone call
Showing the correct battery %
Very happy with my Inspire 2
01-15-2022 17:27
01-15-2022 17:27
01-15-2022 17:27
01-15-2022 17:27
01-15-2022 23:07
01-15-2022 23:07
Mine wont even let me restart… and if i got to dnd it gets stuck and wont let me go back to the main screen… its like the buttons just stopped working… i chatted with support and she couldn’t do nothing other than tell me we will send you an email about warranty… what a joke… so disappointed this is my third fitbit and i think im done… such a waste of money…
01-16-2022 15:43
01-16-2022 15:43
Thank you for reaching out to the Community, @Mary__28, @G-S-C and @Ohlmus. We‘re taking your comments and sentiments in regards to our products into consideration.
Sorry you keep having issues with your Inspire 2. At this point, it's best to keep communication open with our support team. They will be glad to keep assisting you with this.
Thank you for your understanding.
03-12-2022 10:16
03-12-2022 10:16
Many thanks. Immediate solution!
06-29-2022 08:27
06-29-2022 08:27
For anyone that is struggling with this and have tried everything that is on this forum, the issue may be that your phone is on do not disturb or in silent mode.
To update this:
1) Go to your FitBit app on your phone.
2) Click on the "Inspire 2" tab.
3) Click on "Notifications" in the 'General' section.
4) You may see a warning in regards to this on top. If you want your FitBit Inspire 2 to vibrate regardless of the the DND/silent status of your phone, then turn on "Always Vibrate" in the 'Vibration Settings'.
Try all of the options suggested by others as well, such as turning off DND and sleep mode on the FitBit. I hope this helps anyone struggling. Happy FitBitting!
08-13-2022 04:08
08-13-2022 04:08
A late reply to this msg, but have discovered if you switch DND to ON, you can then switch Exercise to ON, and then switch DND back to OFF without affecting exercise. Weird, but it works.
08-13-2022 05:06
08-13-2022 05:06
