01-23-2024 11:47
01-23-2024 11:47
There's no option for selecting "bike" under manual exercise and I've been for 2 bike rides and it's not automatically tracking it either.
I've already restarted my fitbit and deleted and reinstalled the app on my android phone.
01-24-2024 10:21
01-24-2024 10:21
@ENeill , A warm welcome to the Community! Thank you for your message and the screenshot.
There seems to be a misunderstanding here. The screenshot shows, that you are trying to use MobileRun.
This feature uses the information from your phone and was thought to be used if you left your Fitbit at home, and still want to record your steps.
You'll need to start to record your activities from your Inspire 2. Scroll down on the clock face. Tap on the exercise app and select bike. Follow the instructions on the screen to start your recording. More about this can be read here: How do I start and stop a workout on my Fitbit device?
To use Smart Track (autorecognition) you'll need to make sure that the option is on. More info can be found here: Can I change how my activities are tracked?
Best Answer01-27-2024 16:33
01-27-2024 16:33
Thanks - I bought second hand and only had the basic instructions online; it never occurred to me to swipe up on the clock face; only down
I have had smart track enabled so I'm still not sure why it's not tracking them that way but now that I can do it manually it doesn't matter.
Much appreciated
Best Answer01-28-2024 08:36
01-28-2024 08:36
@ENeill , Thank you for your reply. I'm glad that the infos were helpful.
If you purchased the Inspire 2, second hand, it might need some time to "learn" your movement patterns to recognize the activity!
Try recording your rides manually for some days. The tracker should then start autorecognizing the pattern .
I'll leave you the link for the instructions manual for the Inspire 2 here.
