Inspire HR- 250 step reminder
ANSWERED
Hello,
Is there a way to check how far along you are with getting your 250 steps per hour before it buzzes and reminds you 10mins before the end of the hour?
Thanks!
Cindy
1 BEST ANSWER
Accepted Solutions
@Cyndyr777 wrote:
Hi I am actually looking to see if there is a screen that shows something like: 173 steps out of 250 display so i know how many I have left before the warning buzz. Thanks!
And that is exactly what I described.
Do you mean that you want to see it on the main clock face without having to change screens?
6 REPLIES 6
Yes.  From main clock face screen, scroll down (swipe up) a few screens and you will come to a screen showing  '# of 250'.  If you have reached 250, I think it changes to showing how many hours your have hit 250+.
Thank you! When I checked I must of hit the 250 so I was confused. Thanks!
Thanks for that information.  I've been wanting it for a while now.  I find I don't get the warning buzz at 50 minutes after the hour that I would like to correct.  I've checked to verify that the warning buzz is set up, but I'm still not getting it. Thanks,
Hi im looking for the same function on my Fitbit Versa 4. It only shows how many hours i have been active (4 out of 11), but not how much steps im in the current hour.
