10-08-2020 10:09
10-08-2020 10:09
Connected GPS has stopped working on my Inspire HR paired with my Android phone since the latest updates. Before I would start my run from my Inspire, which would connect to my phone and get a GPS signal, and keep that signal no matter what I did with my phone.
Now to get an initial GPS signal I have to have the Fitbit app open on my phone, and to keep the signal I have to keep the phone unlocked and the app open.
This is clearly not working as intended.
I have tried reinstalling the app, restarting the Inspire. All permissions are set correctly and the battery optimisation is off. This is something that has been broken by the update.
10-11-2020 23:54
10-11-2020 23:54
Ok for anyone who comes across this, I think I've fixed it. I have the app GPS permissions when I first installed it, but the default Yes option for Android 11 is allow "Only when the app is in use". I dug down into the app permission settings and changed it to "All the time". Guess it an Android security issue and not down to Fitbit but I think there needs to be some sort of warning in the app that you'll need to do this.
10-11-2020 23:54
10-11-2020 23:54
10-12-2020 11:08
10-12-2020 11:08
I just checked my settings and had it "only when app is in use" as well. I just changed it, so we'll see what happens tomorrow morning when I head out. It would be great to have this resolved!
