06-16-2019 07:28
06-16-2019 07:28
I got a typical low battery notification on my phone so I held the button to check what percentage it was on but it'd just vibrate and stay on the same screen. I cant use any of the functions by tapping on the screen or swiping for a few minutes then after awhile I can tap the screen to scroll through the quick stats but I can't swipe up or down and if I try to hold the button it will freeze the screen again.
I tried to restart it (plug it in and hold the button for 5 seconds) but nothing would happen other than it vibrate and then the screen would timeout.. Do I just have to wait till it dies?
Best Answer03-12-2020 16:35
03-12-2020 16:35
03-12-2020 16:45
03-12-2020 16:45
03-12-2020 17:55
03-12-2020 17:58
03-13-2020 04:27
03-13-2020 04:27
03-13-2020 07:24
03-13-2020 07:24
Go to the fitbit app on your phone
04-03-2020 07:52
04-03-2020 07:52
How do you change the clock face?
04-03-2020 08:28
04-03-2020 08:28
04-04-2020 07:37
04-04-2020 07:37
Thank you! This was the best response for the inspire HR 🙂 the clock face can not be easily changed on our small clocks as easily as it can be changed on the square watches. Thanks again
04-04-2020 07:39
04-04-2020 07:39
Thanks Sandy 68!
Plug in watch, hold for 5 seconds and then it restarts and watch works again for inspire HR
04-04-2020 07:42
04-04-2020 07:49
04-04-2020 07:49
04-21-2020 06:56
04-21-2020 06:56
Wow so simple! Thank you and now I have a cute owl face on my watch.
Thank you
