02-16-2020 21:02
02-16-2020 21:02
Hello there - just wondering if anyone else is having with their inspire HR showing the interval results on the app wrong. I have mine set up to work 45 seconds rest 15 seconds, but on the app when I sync it shows I have done nothing for 45 seconds and moved for 15 seconds. - Please help
Best Answer02-17-2020 04:34
02-17-2020 04:34
@Diane197642 Your interval settings are made on the app, so your issue is more likely an app issue, not a device issue. Which app do you use, iOS or Android?
Laurie | Maryland
Best Answer04-22-2020 08:06
04-22-2020 08:06
Same issue... any resolution?
12-12-2020 19:35
12-12-2020 19:36
12-12-2020 19:36
I use iOS and have the same issue with my inspire hr.
04-18-2021 05:26
04-18-2021 05:26
Same issue. I tried to change the setting from the website but still the same. Mine is android phone.
Best Answer12-07-2022 17:46
12-07-2022 17:46
Same issue. Interval workout log on phone app shows Lap 1 as type REST, it should be MOVE, causing all subsequent laps to be incorrect as well.
Google Pixel 4A and FitBit Charge 5. Firmware version 57.20001.171.50, latest as of 12/7/2022. FitBit app version 3.71.fitbit-mobile
Original report was over 2 years ago. Support please update this thread with the fix. There is a fix by now, right???
