10-26-2019 12:16
10-26-2019 12:16
I bought my Inspire HR a little less than a month ago. It charges, syncs, and does everything except display anything on the screen. Has anyone else had this problem?
10-26-2019 14:30
10-26-2019 14:30
Currently happening to mine - exact same problem.
10-26-2019 17:35
10-26-2019 17:35
Same thing happening to me
10-27-2019 04:19
10-27-2019 04:19
Mine started doing that last night too! Wonder if you can do a hard restart on these
10-27-2019 06:17
10-27-2019 06:17
I called customer service, and after 30 mins of rebooting, syncing, etc. it was determined the device was in need of replacement. I was told there had been no other reports of this issue, so I urge you to call
10-27-2019 09:18
10-27-2019 09:18
10-30-2019 12:42
10-30-2019 12:42
I just checked the screen and now it works all of a sudden. I don't know what changed.
10-31-2019 20:21
10-31-2019 20:21
It happened to me as well, then the screen came back on for about two months, now I'm back to no display
11-01-2019 01:41
11-01-2019 01:41
11-10-2019 10:17
11-10-2019 10:17
Same thing just happened to mine. Called fitbit and they said this is not a "known" issue. Clearly others are experiencing this though. Fitbit, get it together --- this is clearly a product/software defect.
11-10-2019 15:31
11-10-2019 15:31
According to the older threads this is not a new issue and there are dozens of complaints gluing back a year about the Inspire HR display fling dark, and that despite months of complaints about the same problem, replacement is still the only fix. Fitbit hasn't done anything proactive. I wish i had seen the threads before i bought mine.
11-10-2019 16:18
11-10-2019 16:18
I live in an area where the clock changes by an hour twice a year. I was using my Inspire HR clock to reset my stove, microwave, etc. The display showed a couple of unusual small icons and then blacked out. It's been dark since.
I realize it's under warranty - I've had it less than 2 months - but won't file a claim if I have to send this one back to them. I don't want to be without it for several weeks. It still works - I just can't view anything on the Inspire itself. Did the restart also - no luck.
