08-16-2020 20:32
08-16-2020 20:32
Yesterday my Inspire HR started buzzing randomly and then started scrolling through the menu without being touched and then went black. I've tried charging it and restarting it both on a charger plugged into a wall and one plugged into a computer. There is no response. I ran it across the charger touchpoints and a couple of times it would barely start to show something on the screen and then go back to black. It has been black since then for most of the day today. The app can't get a connection with it either.
08-17-2020 03:50
08-17-2020 03:50
Oh dear, @AlliCart , that doesn’t sound good! It might help to give the charging contacts a clean. Here are the instructions:
Once you have given them a good clean, try plugging in again using a wall socket. Give the Fitbit a good two hours charge, even if it does not seem to be responding.
Once it has had two hours charge, try the restart procedure again, only this time instead of holding the button for 5 seconds as usually recommended, try the long button hold - up to 20-30 seconds. Make sure the Fitbit stays attached to the charger the entire time you are holding the button.
With luck, that will bring your Fitbit back to life. If not, it is time to get in touch with Customer Support on Contact,fitbit.com . Be sure to tell them the troubleshooting procedures you have already tried, as that will save time.
Good luck and let us know how it goes. Welcome to the forums!
