10-01-2019 08:04
10-01-2019 08:04
I have silent alarms set for every day to remind me to take medication. It works on some days but not others. I have deleted the alarms and reentered them but still have this problem. I have iphone with 13.1 loaded. This was happening before the Apple update but have not had the update long enough to tell whether it is worse now.
Best Answer10-02-2019 00:36
10-02-2019 00:36
Hi @JMerrill That sounds really annoying! Id suggest you remove the alarms in the app and sync the tracker. Then restart your Inspire HR several times and then add the alarms back and see if that fixes the problem for you.
Helen | Western Australia
