06-23-2020 12:45
06-23-2020 12:45
My device is new, fresh out of the box and I have never used one before. I downloaded the app, made an account, and plugged the Fitbit into the charger as indicated. It lit up, it is charging (93% battery right now).
I have looked at the troubleshooting webpage here, I have looked at the steps indicated in other posts on this subject. I've:
uninstalled the app
reinstalled the app
logging out and logging back in
Tried the app on my windows PC
Turned off the bluetooth and turned it back on
Checked my permissions for location data and bluetooth for Fitbit (it is Always On/Available)
Restarted the Fitbit
disconnected and reconnected the chargee to the Fitbit
Restarted my phone twice
Now what? I can't just use something else because the Fitbit is required for a medical study. I really need it to get going and the app store (Google) is filled with people saying the entire app is broken. This is frustrating.
Best Answer06-23-2020 12:51
06-23-2020 12:51
Repeated:
Turned off bluetooth and turned it back on
Tried to restart the Fitbit (can't, the smile appears and then it is back to the set up url scrolling across the screen)
Closed and reopened the Fitbit app
UGH
Best Answer06-23-2020 13:44
06-23-2020 13:44
Make sure it’s the right model you are trying to set up
08:13
09:55
07-02-2020
08:13
09:55
@WTFrenchToast It's great to see you in the Community!
Let me help you with your setting up your Inspire HR with your phone and thank you for troubleshooting this issue. Try clearing the bluetooth link between your phone and your tracker by doing the following:
@Mand0l0rian thank you for pointing this out as it is important to select the correct model when setting up your Fitbit device.
Let me know how it goes.
Best Answer07-03-2020 03:43
07-03-2020 03:43
Every time I want to sync, I have to restart my computer or else the connection cannot be made.
Does this ever get better? It's painful to sync - is a fix for this bug being worked on? Can we expect it soon?
