Inspire HR Way to Improve Button life
Is there a way to turn off and on the display of the Inspire HR so that I can improve the button life of the fitness tracker. Also I need the gestures for these too:-
1. Returning home without using the button in the tracker
2. Turning of the screen off the fitness tracker immediately without using the button
It will be helpful if I get answers
Thanks
1 REPLY 1
Hi @JohnsonPrince  The answer to your questions is no, there isnt.
You dont need to use the button for many processes, but the ones that need the button have no other way of navigating.
Edited to add - in the three trackers I have had with buttons there has never been a problem with any of the buttons. Button failure has a very small number of posts on the forums, so I would say the liklihood of having a button problem is minimal.
Community Council Member
Helen | Western Australia
