04-08-2019 07:26
04-08-2019 07:26
Hello - When I am in the running exercise mode, my Inspire HR vibrates constantly. I went in and turned off cues, but that didn't help. I am not sure why it is vibrating as it does not seem to do so at every .25 mile or minute mark. Please help! The vibrations are throwing off my running.
06:03
06:20
04-09-2019
06:03
06:20
@LeiaD Welcome to the Fitbit Community! I hope you're doing well!
I will gladly assist you with your Inspire HR that is constantly vibrating. Please restart it by following these instructions. If the issue persist then try a Factory Reset but note that you will need to set it up again.
Let me know how it goes.
Best Answer05-21-2019 13:20
05-21-2019 13:20
The same thing keeps happening to me! My fitbit shows a little box in the bottom left corner with an x in it, and then it vibrates and the x goes away. literally 60 seconds later, it does it all over again.
08-05-2019 17:15
08-05-2019 17:15
Did you ever manage to figure this out? I just got my Fitbit inspire Hr and the constant buzzing during a workout is driving me crazy
08-05-2019 17:52
08-05-2019 17:52
No. Never solved. I just stopped using it. Complete waste of money.
08-05-2019 18:15
08-05-2019 18:15
I ended up turning off GPS. It’s working so far. Not sure what the point of GPS is if it never works!
08-31-2019 07:27
08-31-2019 07:27
Same issue. Can't believe this was never fixed. So dumb.
09-06-2019 15:26
09-06-2019 15:26
This is now happening to me. If it doesn't stop I will be returning my fitbit as I bought it for the purpose of tracking runs and it's instead ruining them. Is there a solution for this yet?
Best Answer09-06-2019 18:54 - edited 09-06-2019 18:57
I had this issue when i got the device, and I solved it.
I noticed when I'd set an exercise for walk and walk in the house, or go without my phone, nothing would vibrate. So I thought my phone and fitbit must be trying to connect, and as it only happened during walking (I don't run) it couldn't be a sync issue, but a gps issue. Because there is no on board gps, it tries to connect to your phone. When it struggles to connect it vibrates. I have my settings on my app set to connect all day, but even that wasn't good enough. Then I realized I have battery saver on my phone. I'm on a Samsung S7.
Here are 3 fixes that worked for me:
All of those options worked and fixed it. I wish there was a more permanent fix on fitbits end, especially since there are so many posts on this.
