07-08-2019 20:24
07-08-2019 20:24
Hello,
I bought Fitbit one month back. I thought as Fitbit is global brand it will provide great services in return but seems like it failed to provide basic services itself like it does not sync by default we need to do the Bluetooth on off then in notification we have to click on sync... If you create a device at least you should make your device in such a way that it will sync by default once phone where device installed and watch are in nearby area ... To be honest China products are more good than your stupid Fitbit... you should work on your stupid product first then launching new models...
06:37
06:10
07-09-2019
06:37
06:10
@SandhyaBelekar, it's great to see that you've visited the Fitbit Community!
Let me help you syncing your Inspire HR with your phone. Which phone are you using? Is it compatible? You can try the following:
I personally have a Xiaomi MI 8 lite and I am able to get notifications and sync with my device.
Let me know how it goes.
Best Answer07-13-2019 20:59
07-13-2019 20:59
Hello,
I have tried all the options multiple number of times but nothing gives outcome of automatic sync data.
Could you please tell what's the way to make my Fitbit watch and mobile in sync ?
Thanks,
Snehil
