03-16-2019 09:19
03-16-2019 09:19
Hello everyone!
I recently got the Inspire HR and I purchased the clip Accessory because I already have an Android Wear watch that I like for other stuff. I don't recall anywhere previously saying that the HR wasn't compatible with the clip and the user guide mentioned that Clip On/Off toggle that I had used prior to the most recent update.
Now I see that the option is gone and the marketing says that the clip is not compatible with the HR. What happened? Did I just miss this somewhere before I purchase my clip? I use the band for sleeping and workouts, but I wanted to use the clip for when I'm just walking about.
Is it truly not compatible anymore? Will readings be accurate? And if not, can I get a refund because the marketing and options on the device lead me to believe that it was compatible when I purchased?
Best Answer04-05-2019 19:04 - edited 04-05-2019 19:04
Update— I received my clip...put my Inspire HR in it.... fits AND works perfectly.
04-10-2019 12:53
04-10-2019 12:53
Sounds like anyone that has a clip that was intended for the NONHr is finding that it works fine AND that it fits. I understand that the HR is a bit taller than the nonHR, so that was a concern I had about buying a clip. Looks like that although it may not be perfect an HR can indeed fit in the NonHR clip. Time to shop a bit? 😉
Best Answer04-12-2019 08:19 - edited 04-23-2019 11:03
Dear @Dan- ,
I am sorry you took offence from at fitbit form posts phrasing,
I would however, like to clarify.
I used the word "So" as an adverb,
definition = in that manner or fashion: thus: in the aforesaid state or condition: to the extent or degree indicated or suggested.
You took it as the informal adverb: Very or extremely.
I am sorry for any confusion that caused.
Best Answer04-22-2019 05:35
04-22-2019 05:35
It seems to record the steps accurately when it is in the regular Inspire clip. But it gives you little messages that it can't track stages of sleep and heart rate. I need to use the clip because I am allergic to nickel and the band has nickel on the fastener. I can tolerate the band while swimming or when the fastener part is wrapped in fabric, but I don't want to constantly have to deal with keeping the nickel touching my skin.
Best Answer04-23-2019 11:01 - edited 04-23-2019 11:02
how does your HR have a clip mode?
Best Answer04-23-2019 17:47
04-23-2019 17:47
05-12-2019 07:43
05-12-2019 07:43
Nothing is accurate on the inspire he especially the step count. So disappointed and can’t return to the store. Why can’t you provide a fix for the step errors everyone complains about?
Best Answer05-12-2019 15:57
05-12-2019 15:57
I bought this because 90% of the time I plan on wearing it on my wrist and using the HR features. Occasionally I want to wear a dress watch and would like to get my steps counted during that time. I was so happy that I would be able to use one device.
I have an an old Ultra that I was going to use in conjunction with my Charge 2, but they no longer support syncing with the ultra.
I’m very disappointed because the inspire feels so much better on my wrist than the charge 2.
Best Answer05-20-2019 16:55
05-20-2019 16:55
You're fortunate your One still works. Mine crashed several months ago. LOVE the One and can't find a watch that fits my small wrists. Way too clunky. Was excited about the Inspire HR, but So want it to function for steps, etc in a clip. Maybe Fitbit will smarten up.
06-02-2019 13:17
06-02-2019 13:17
06-06-2019 11:55
06-06-2019 11:55
I bought a Fitbit inspire hr. There was no information saying it was compatible with the clip on. It would be nice if you enabled the clip on mode
06-17-2019 06:33
06-17-2019 06:33
I bought the Inspire HR through a work deal, not knowing that it wasn't meant for the clip - the work website was not that detailed about it, and my work price was soooo low that the HR sounded very appealing. I thought it worked in the clip based on what I had previously read about Inspire months ago. I never was into wrist trackers but I thought the HR would be good for exercise days. I planned to wear the clip most of the time.
Since I bought through a work deal, it would be a major pain to return, so I bought the clip anyway and I am experimenting. After a few days, I'm simply not sure about the accuracy. I am still wearing my BellaBeat right now to compare, but the numbers I am getting between the two vary. I don't know which is accurate as I have not had time to do a formal test and I am just comparing my numbers at the end of the day.
Here are my stats from the last 4 days. I am going to continue experimenting for a little while longer. I wasn't very happy with the large difference I got yesterday.
| BellaBeat minus Inspire HR | Location |
| 362 | in Pocket |
| 285 | Wrist |
| 1109 | Wrist |
| 1738 | Clip |
Best Answer06-21-2019 02:42 - last edited on 10-30-2019 14:46 by LiliyaFitbit
Hi there,
so I just want to confirm that the Inspire HR can be worn in the Inspire clip but is not that accurate in counting steps? I specifically bought the HR for the all the features and I have to wear the clip at work due to infection control protocol is this correct ?
Moderator edit: format
Best Answer06-21-2019 04:41
06-21-2019 04:41
07-09-2019 09:35
07-09-2019 09:35
I wear it as a clip on both my waistband (when I have no pockets) and my top (when I have no pants) and in my pocket most of the time. I'm finding it to be pretty accurate in my random testing and my daily totals.
07-09-2019 10:02
07-09-2019 10:02
Hey Folks!
So its been a while since I made this post and I want everyone to heed my warnings.
So the clip is fine and is accurate enough to keep on the clip (though the wristband does seem more accurate overall. It just depends on your general movement as there doesn't seem to be consistency one way or another in regards to a set number of steps between clip vs wrist. If anything, I'm more annoyed that the Inspire HR inaccurately counts me "talking with my hands" as steps in my desk job where I haven't even stood up).
However, the warning comes in form of the fact that the HR is slightly taller than the regular Inspire. Because of this, the Clip sorta has the Inspire HR a bit weirdly placed and tight in the clip. Now you'd think that this would mean that it's more secure in the clip, but it's actually the opposite. Because its weirdly shaped slightly, it protrudes out a bit more and can snag a bit more easily than the regular Inspire.
Long story short, I lost my Inspire HR! I was out shopping in multiple stores one day and I had my HR in the clip and when I came back home, I noticed that my clip was still in tact but the HR was missing from it!
I did a lot of heavy lifting of big boxes this shopping day, and I think I lost it when I was handling a large box that was rubbing against my belt loops with the clip and HR.
I tried my best to retrace my steps to find it, but I couldn't find it. I even used the "Last Sync" time to retrace back to the relative time at which store I was in when this occurred. I unfortunately never found it.
So long story short, clip seems fine but with it being a slightly different size than the regular Inspire it seems to run the risk of being able to escape the clip more easily.
It's unfortunate because I did like the HR, especially for HR based sleep tracking. But it looks like I won't have a Fitbit again any time soon because there isn't a clip style fitbit that fits my needs at the moment. Hopefully down the road there will be.
Either that, or wait for the regular Inspire and settle for the basic sleep tracking to go on sale or something so I can make use of these now useless wristband and clip I now have.
09-02-2019 22:02
09-02-2019 22:02
I just bought the Inspire HR and like it, but would like the option of the clip at sometimes, like on a treadmill. I was just wondering if you have continued using the clip at times and how it is working for you.
Best Answer09-02-2019 22:17
09-02-2019 22:17
I haven't measured differences, but other than no HR I haven't seen much difference with using it in the clip or on my wrist.
Best Answer09-03-2019 04:38
09-03-2019 04:38
Best Answer09-03-2019 04:56 - edited 09-03-2019 04:57
I wear mine exclusively as a clip and, as mentioned above, it seems pretty accurate. The other day I tested it again. I walked a mile and the steps calculated out right at around 2000 steps which (according to google) is how many steps are in a typical mile 🙂
