03-16-2019 09:19
03-16-2019 09:19
Hello everyone!
I recently got the Inspire HR and I purchased the clip Accessory because I already have an Android Wear watch that I like for other stuff. I don't recall anywhere previously saying that the HR wasn't compatible with the clip and the user guide mentioned that Clip On/Off toggle that I had used prior to the most recent update.
Now I see that the option is gone and the marketing says that the clip is not compatible with the HR. What happened? Did I just miss this somewhere before I purchase my clip? I use the band for sleeping and workouts, but I wanted to use the clip for when I'm just walking about.
Is it truly not compatible anymore? Will readings be accurate? And if not, can I get a refund because the marketing and options on the device lead me to believe that it was compatible when I purchased?
Best Answer09-13-2019 13:14
09-13-2019 13:14
I'd like to go back and forth between the clip and wrist but am concerned the clip would cause damage to the HR monitor. For those of you who do the same, does it damage the HR monitor such that the monitor would not work if you switch back to the wrist? Or can it switch back and forth? Thank you.
Best Answer09-13-2019 16:02
09-13-2019 16:02
09-13-2019 18:41
09-13-2019 18:41
09-16-2019 17:32
09-16-2019 17:32
Hi I just got an inspire hr and I also purchased the clip. I tried pressing the side button for 2 seconds as it says and swiped up but I’m not getting anything that says clip or watch option. What am I doing wrong?? Thanks
Best Answer09-16-2019 18:50
09-16-2019 18:50
Best Answer09-16-2019 20:06
09-16-2019 20:06
10-20-2019 11:16
10-20-2019 11:16
I also purchased the inspire HR to replace my fitbit one.
I was excited about the clip option because I can not always wear it on my wrist.
I like the possibility of changing back and forth from wrist to clip.
Any chance that would be a possible option for the Inspire HR in the future?
Best Answer10-24-2019 19:59 - edited 10-24-2019 20:07
Sorry reading these comments and just not sure of the clip does or doesn't track steps while in the clip...will keep reading the posts! Thanks
Best Answer10-25-2019 04:33
10-25-2019 04:33
10-25-2019 05:01
10-25-2019 05:01
11-17-2019 04:18
11-17-2019 04:18
Your answer is very disappointing for two reasons.
1) I don’t like how big the inspire is compared the the flex 2 therefore I want to hide the device
2) and when I googled inspire hr clip, your marketing made me believe it would still track HR
i only bought the HR for the sleep tracking which I guess if you’re not wearing it on your wrist doesn’t work.
ive been a long time user and fan of Fitbit but really considering throwing in the towel. And I’m not the only one. This is a discussion that I’ve had with other like minded friends. I’m very frustrated and seem to be spending too much time being frustrated. Guess it’s time to let it go.
11-17-2019 12:08
11-17-2019 12:08
Matt - I ordered the clip with my Inspire HR. Haven't used it yet, but am dismayed to hear it won't work. I bought so I wouldn't need to wear the band when going to upscale dinner with clients. Is it possible to get a refund?
Best Answer11-18-2019 07:04
11-18-2019 07:04
Best Answer11-27-2019 21:04 - edited 11-27-2019 21:06
@Donnalu22If you are using the clip it works very well with the Plain Inspire
The HR model is bigger and does not fit well
Wendy | CA | Moto G6 Android
11-27-2019 21:42 - last edited on 06-18-2020 19:01 by LiliyaFitbit
The Fitbit Inspire HR fits nicely into the clip I purchased on Amazon.
____________________________________________________________
Moderator edit: content
Best Answer01-22-2020 21:51
01-22-2020 21:51
I just received an inspire HR for Christmas. I started using it with the clip a few days ago, and it seems to track my steps just fine. So far I’m happy with it
02-28-2020 18:30
02-28-2020 18:30
It seems counter-intuitive to take the option away. I have severe arthritis in my wrists and can't wear anything there. I'm hoping the count is close to accurate.
And yes, the Inspire HR Users guide still talks about the 'clip' option.
03-21-2020 09:30
03-21-2020 09:30
I am in the same boat as many as I read though this board that I need to replace my 4+ year Fitbit One. The HR model has everything I want, but the clip mode that Fitbit removed. From reading it does seem like people are having good luck still using it clipped.
Are you using the Fitbit clip or are you finding 3rd party ones to be better?
When using it as a clip is there anything I need to do in setting?
Thanks
Best Answer03-21-2020 09:43
03-21-2020 09:43
Best Answer03-21-2020 10:02
03-21-2020 10:02
