07-11-2020
08:13
18:24
LizzyFitbit
07-11-2020
08:13
18:24
LizzyFitbit
My Inspire HR band wont stay attached. It's not the band but the Fitbit itself. Only had it less than a year. Looked at other comments, seems to be a common problem.
What to do now?
Moderator Edit: Formatting and clarified subject
07-11-2020 16:26
07-11-2020 16:26
Hello @Jmurdough, welcome to the Fitbit Community forums.
Thank you for all your feedback and for sharing this information about what you've experienced with the band of your Inspire HR.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Keep an eye on your inbox.
Let me know about te outcome.
07-12-2020 07:12
07-12-2020 07:12
I am also experiencing this same issue with my band and fit bit. I have used it lightly and I am having the same problem. I spend a decent amount of money on this item and for as little as it has been used and as good as I have treated it in less than a year I am disappointed I can no longer wear it.
I would like to know what options I have to correct this problem.
Thank you
07-12-2020 14:35
07-12-2020 14:35
Hi. My daughter & I both purchased & started using out Fitbit Inspire devices recently.
Mine has been fine.
Her battery runs out very quickly, compared to mine, however, at the moment the key issue is that her bands won’t stay attached at all. I’ve checked other advice on the forum, but nothing is helping. Can you follow up please?
07-13-2020
03:04
06:54
DavideFitbit
07-13-2020
03:04
06:54
DavideFitbit
I'm having the same problem, but I've had my Inspire HR less than three months. It looks like the sides of the unit have been chewed on so there's nothing for the bands to attach to. Of course the unit hasn't been chewed on. In fact, it's been used very lightly.
I paid more than $150 for my Inspire HR; it should not be having this issue at all, much less this soon after purchase.
I contacted Customer Support. They sent replacement bands. Still won't attach.
What to do now?
Moderator edit: format
07-28-2020 06:51 - edited 07-28-2020 06:55
Hello, welcome to the Fitbit Community @pink_fit_bit @Aine_C @Larv. Sorry for the late reply.
Thank you for all the details you've provided about the band of your Inspire HR that won't stay attached and for sharing your feedback about this.
@pink_fit_bit @Aine_C, I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Keep an eye on your inbox.
@Larv, I've sent your information to the Customer Support team fas well, but was informed that you already have a case created or that you already got in touch with them.
Keep me posted on the outcome.
07-28-2020 07:49
07-28-2020 07:49
07-28-2020 11:29
07-28-2020 11:29
Mine is only a week old and I’m having this issue. I’m so mad because I got this one because the Alta was no longer available. I never had this problem with the Alta.
07-29-2020 09:37
07-29-2020 09:37
Hi, thank you for your replies @Jmurdough @Amesandbuffy.
I'm very to see that you've experienced this problem with the wristband not staying attached.
@Jmurdough, it is particularly difficult when the device is no longer covered by the warranty, but even tough Support is eager to help with any problem you may experience with the product, they do need to adhere to the official warranty policy, this would start counting from the original date of purchase.
Thank you for taking the time to share your feedback; comments from users are always useful to continue to improving the quality of products and services.
@Amesandbuffy, I've also been informed that you already contacted the Customer Support team for further assistance with this.
Keep me posted.
10-04-2020 21:35
10-04-2020 21:35
I have the same problem with the ends. I’ve had this device since May. Very disappointed that this happened.
10-06-2020 06:52
10-06-2020 06:52
Hello, welcome back to the Fitbit Community forums @alidak. Sorry for the late response.
Thank you for all the details that you've provided regarding the band of your Inspire HR that won't stay attached.
I've also sent your information to the Customer Support team for further assistance with this, but was informed that you already have a case created or that you already got in touch with them.
11-11-2020
11:54
08:22
DavideFitbit
11-11-2020
11:54
08:22
DavideFitbit
Hi, my mum bought me a Fitbit Inspire, its never been used as the strap just wont fasten. Thought there must be a peice missing as this cannot be the actual fastening?!! What can I do? Can you get a normal strap? Obviously a design fault. Was this not tested in a wearer trial prior to production? Cannot fathom how it would stay on.
11-12-2020 08:21
11-12-2020 08:21
Welcome to the Fitbit Community forums @Bamboo8031.
Thank you for your inquiry regarding the inconvenience you've been experiencing with the wristband of the Inspire device.
Before considering other options, could you please provide a few extra details of the problem you're experiencing? Let me know why the wristband won't fasten or what are you seeing exactly then you try to fasten it. If possible, please provide a picture of the band so we can take a better look at what is happening.
Keep me posted.
01-18-2021
22:21
08:05
DavideFitbit
01-18-2021
22:21
08:05
DavideFitbit
I received an Inspire 2 today and I've tried for the past 3 hours to attach the longer band but it won't stay fastened. I even tried putting the shorter band back on but it won't stay attached either. the pin won't stay in on the left side (looking at it from the back)
i fixed it. the problem with mine was that the hole on the problem side was not formed properly. i used a 1mm drill bit to form the hole and now the band attaches.
this is a QC problem that should have been noticed but wasn't. not a happy start.
01-19-2021 06:47
01-19-2021 06:47
I have the same issue - my band will not stay attached. I have tried after market bands too - they also become detached. I thought perhaps it was the pins - but it sounds like it's the hole the pin sits in?
I've only had this for 6 months.....and I've had many a scare where I thought I would lose the entire Fitbit because the pins won't hold and it slides off my wrist!
Fitbit - did you test the bands/pins? What can we do other than try to drill them out ourselves?
01-19-2021 10:48
01-19-2021 10:48
@AScherer if yours is like mine was and the hole/s aren't properly formed, you don't need to use a drill. just use a tiny bit or needle etc to form the hole.
01-20-2021 08:04
01-20-2021 08:04
Welcome to the Community forums @AScherer, and thank you for your reply confirming that you were able to resolve this @MAQuinn.
@AScherer thank you for sharing that you've been having trouble with your Inspire HR wristband. In case you need further assistance, I've sent your information to the Customer Support team, so you should be getting a reply soon.
Have a great day!
03-28-2021
13:55
13:43
DavideFitbit
03-28-2021
13:55
13:43
DavideFitbit
I am having the same problem. I cannot get the band to stay attached. I have only worn it for a couple of months.
Please help me. My Fitbit has only been worn for a couple of months and the band on one side will not attach.
03-29-2021 06:26
03-29-2021 06:26
My daughter has had the same with her's. Got it for Christmas and hasn't been able to wear it for the last few weeks.
03-29-2021 06:35
03-29-2021 06:35
Fitbit sent replacement bands, but apparently, that is not the issue. The actual device has a bit of the plastic missing. It is not from aggressive treatment. The band fell off while I was sleeping. Such a bummer!
