12-30-2019 06:01
12-30-2019 06:01
Hi! I have ben using my fitbit Inspire HR for maybe a year now. This week i noticed that the battery would die almost by the end of each day. Normally I charge it every few days and it seems to be running perfectly fine. I did try to find previous posts that offer multiple suggestions such as turning off certain notifications/settings/etc. I have done that, but still, not much luck. I charged my battery this morning to above 50% (I was running late for work). Now I am at work and the battery is below 30%, and I don't have my charger with me at work.
I noticed there was an update on 12/24 (today is 12/30). Have any bugs been reported since the update? Are there any other suggestions on how to fix this issue?
Thanks and happy holidays!
Jess
Best Answer05-28-2021 14:37
05-28-2021 14:37
Best Answer06-27-2021 06:10
06-27-2021 06:10
I just started having the same problem. Any suggestions
06-27-2021 06:24
06-27-2021 06:24
06-27-2021 09:25
06-27-2021 09:25
10:58
06:08
JuanJoFitbit
06-27-2021
10:58
06:08
JuanJoFitbit
Hi Jogger
Thank you for the info
WalkerST
Thank you barb0710 I’ll brace myself for the challenge
Moderator edit: merged reply
Best Answer07-22-2021 13:54
07-22-2021 13:54
My Inspire HR is draining too quickly as well. I have cleaned the contacts and rebooted as advised, but it was at 99% charge at 12:30 p.m. EST. It is at a 77% charge as of 4:52 p.m. Est. In the same day My boyfriend has a different brand of Fitbit (Charge 3) and is at 30% battery life after 7 days of no charge at all. My battery used to last 5 days and I believe this is a FitBit issue and at least 45 other people have complained as well.
07-22-2021 19:37
07-22-2021 19:37
I had the same battery usage which was unacceptable in under a year. I complained to several representatives as they kept telling me it wasn’t an issue💥 it was under a year and I finally annoyed enough reps that they had me send it back because of the battery usage within 24-36 hours. But they dragged out replacing it for over 2 weeks. Finally got a new one and have had battery issues again. My family bought me a new tracker from another company💥:double_exclamation_mark:
07-23-2021 02:26
07-23-2021 02:26
07-26-2021
12:46
05:04
JuanJoFitbit
07-26-2021
12:46
05:04
JuanJoFitbit
I might have to do that. They gave me a discount code for 35%, and that discount code didn't even work. Their systems said it was applied and nothing was taken off.
What company did you get it from? Clearly FitBit has gone down hill and they're not good at acknowledging their shortcomings.
Best Answer07-27-2021 04:18
07-27-2021 04:18
Hi have the same problem with my firbit inspire hr. its fully charged at 10 am, completely drained by 4 pm. i hope you can also help me. thanks!
Best Answer07-27-2021 04:48
07-27-2021 04:48
Best Answer07-27-2021 15:29
07-27-2021 15:29
hi walker thanks for this. already contacted them and tried troubleshooting. Had mine since 2019 and warranty doesnt cover it anymore. Basically they just told me to purchase a new one because mine appears to be defective. My mom also has one and have the same problem. So sad that it seems like it's disposable after a couple of years. Might not be best to buy a new one since it'll still be broken after a year or two. Mine's not an isolated case, I see a lot of problems like this here at the community, but theirs get replaced, mine doesn't. 🤕
07-27-2021 15:54
07-27-2021 15:54
07-28-2021 11:16 - last edited on 07-28-2021 12:59 by LiliyaFitbit
They took down my last post without acknowledging their INSPIRE HR product has issues
Best Answer10-06-2021 07:44
10-06-2021 07:44
Same issue. 2 year old Inspire HR. Chugging along fine and I love it. All of a sudden it won’t hold a charge longer than 4 hours. I understand it needs a new battery. I have no soldering tool, nor the dexterity to do it myself. Can anyone recommend a place to take or send it to ( in the US) for a new battery? Or do I just ditch it and get a new one? 😢
Best Answer10-07-2021 14:14
10-07-2021 14:14
Best Answer10-07-2021 15:09
10-07-2021 15:09
Best Answer05-24-2022 03:39
05-24-2022 03:39
How do they make a product where you can’t replace the battery?? That is so wasteful!! I’m so upset.
Best Answer09-08-2022 03:29
09-08-2022 03:29
Do you have a number for the Helpdesk? Finding that info seems very difficult..
Best Answer09-08-2022 03:34
09-08-2022 03:34
My Fitbit inspire 2 started dying suddenly 3 days ago. My Fitbit says it was setup up Dec 12, 2021. How do I arrange a replacement unit?
