Inspire HR battery draining way too quickly - possibly since update
Hi! I have ben using my fitbit Inspire HR for maybe a year now. This week i noticed that the battery would die almost by the end of each day. Normally I charge it every few days and it seems to be running perfectly fine. I did try to find previous posts that offer multiple suggestions such as turning off certain notifications/settings/etc. I have done that, but still, not much luck. I charged my battery this morning to above 50% (I was running late for work). Now I am at work and the battery is below 30%, and I don't have my charger with me at work.
I noticed there was an update on 12/24 (today is 12/30). Have any bugs been reported since the update? Are there any other suggestions on how to fix this issue?
Thanks and happy holidays!
Jess
62 REPLIES 62
Oh yes… it was ordered directly from Fitbit, not bought at a store.
Hi
It’s been a while since I contacted them but I
started by accessing the app and touching my picture in the upper left corner which accesses the menu. Go to help and support- contact customer support- follow the prompts. When
you chat with them I think a number pops up.
Hope this helps you.
Thank you.  I did end up getting through to them and my replacement one has been ordered.
