Inspire HR battery life
Help needed.
I bought this device as it was smaller than my versa but still gave me notifications and everything else I wanted including a five day battery life. However since buying it I have not had anything longer than 24 hours and less. I have turned off notifications and sync function. I have rebooted the device several times and it still runs out and with everything turned off it is not giving me what I wanted and less. How can I resolve this any ideas??
3 REPLIES 3
Hi @Fudge1079  That is not very good battery life. Mine lasts several days with notifications and all day sync turned on. I have flagged a moderator to come and help you
Community Council Member
Helen | Western Australia
@Fudge1079, a warm welcome to our Community!
Let me help you with your Inspire HR battery life and thank you for troubleshooting this issue. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
@NellyG thank you for your help here.
Let me know how it goes.
Alvaro | Community Moderator
Hi,
I did as suggested and managed to get 10 hours.
