04-18-2023
04:34
06:36
WilsonFitbit
04-18-2023
04:34
06:36
WilsonFitbit
I have a replacement Inspire HR that i got with the warranty last year. The battery life had been dwindling to a few days, but this weekend it went to 6 hours. and now it is down to 3 hours and that was sleeping hours, not moving or using the screen. I have not changed any of the setting to cause this. Any Ideas?
Moderator edit: clarified subject
Best Answer04-19-2023 09:37
04-19-2023 09:37
Try a restart and see if that helps. Then try this: remove the device from the account and then reconnect it. Clean the contacts with rubbing alcohol and charge overnight.
But it sounds like my Inspire 1 that just failed. Was working perfectly ok, until it would drain within a few hours first, and most recently it would go from 100% to 7% in less than 2 hours. I did get 4 years of use out of it, though.
04-22-2023 12:01
04-22-2023 12:01
At least you had it for 4 years. I have never had a fitbit work for that long. I am trying an amazon version of an Apple watch for a fraction of the price. I will see how long it lasts.
11:14
12:05
04-24-2023
11:14
12:05
Hi @JB412 is good to see you around and thanks @brutus001, for the steeps provided.
Actually, there are some factors that could affect the battery life of your device. I suggest checking the article to learn a little bit more about that. "Can I extend my Fitbit device's battery life?". If you have already take this tips in mind, I recommend to rich our support team out to get a suitable resolution.
