09-30-2021
17:41
04:55
AlvaroFitbit
09-30-2021
17:41
04:55
AlvaroFitbit
How do I insert a new battery.
what type of battery do I need to buy.
09-30-2021 18:14
09-30-2021 18:14
Hi @queenscliff there is no battery replacement for these devices.
09-30-2021 20:04
09-30-2021 20:04
09-30-2021 20:29
09-30-2021 20:29
You sure it's an Inspire 2? Maybe it's telling you that you need to charge the battery because it's low? There are no replacement batteries for any of the Fitbits. The Aria Air scale uses batteries and the no longer for sale Zip takes a button battery. The other wrist based devices are rechargeable and they can't be replaced.
10-01-2021 00:54
10-01-2021 00:54
10-01-2021
04:54
08:58
10-01-2021
04:54
08:58
@queenscliff Welcome to the Fitbit Community!
Sorry to hear about this. As @Odyssey13 kindly explained your Inspire HR's battery can't be replace. I suggest you try these suggestions to help improve the battery life on your device.
I also moved your post to the correct board.
Hope this helps.
10-01-2021 06:52
10-01-2021 06:52
That is so strange @queenscliff you're message - you have any way of taking a picture of it?
10-01-2021 14:28
10-01-2021 14:28
