01-17-2021
23:34
03:08
JuanJoFitbit
01-17-2021
23:34
03:08
JuanJoFitbit
I got this used Fitbit for Christmas and I've been loving it until it randomly stopped holding charge. It dies in less than 2 hours. I see tried restarting it, rebooting it completely, and charging it over night. It's broken and I'm very disappointed.
01-18-2021 03:07
01-18-2021 03:07
Hi @CiaT, welcome to our Fitbit Community. Regarding the battery draining issue that your Inspire HR has experienced, I appreciate the time spent trying to get it resolved before contacting our forums.
I'd like you to try the tips that are listed in this help article in order to improve the battery life of your Fitbit device. After this, charge it for 2-3 hours and see if the battery doesn't drain fast.
Keep me posted on the outcome.
01-19-2021 09:26
01-19-2021 09:26
I have tried those things and it doesn't do much. It still won't last a full night. Also, it's not cool that in order to make the battery survive a tiny bit longer, I can't use several of the functions.
01-23-2021 08:52
01-23-2021 08:52
Hi @CiaT, thank you for getting back and trying the recommended tips. Since the issue persists, let me go ahead and forward your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
I'll be around if any question arises.
03-16-2021 10:32
03-16-2021 10:32
Hi
Did you get an answer? I have the same problem 😕
03-16-2021 10:33
03-16-2021 10:33
Hi
03-16-2021 10:40
03-16-2021 10:40
03-16-2021 11:37
03-16-2021 11:37
03-17-2021 00:35
03-17-2021 00:35
I have exactly the same problems. I've read on here it could be a possible firmware issue. Not good as still under warranty and have to stop using because it needs charging all the time!!
