09-15-2020 20:45
09-15-2020 20:45
Hi,
I purchased a Inspire HR in July. I found a problem that my Inspire HR constantly holds the exercise mode while I am sitting. When it happens, I cannot go back to the clock face by pressing the side button. Also, even though I make it finish the exercise mode and it keeps holding the exercise mode more than 5 hours. With the same problem, I have to reset it a couple of times last month. Now, I have the same problem every 2 or 3 days.
Today, my day was pretty sedentary, but my dash board shows RUN 52 mins which was wrongly holding the exercise mode.
Any suggestions?
09-15-2020 21:06
09-15-2020 21:06
The simplest way out of a run is: button, button, tap 'finish' on screen, button.
When you finish a Run, first press side button puts it in Pause, and, like the screen says 'press button to finish exercise'; Press button again to finish or tap arrow to resume; after you press the button again, it says 'FINISH' with 2 flags; either tap 'finish' or scroll down to tap left arrow to continue run; when you tap 'finish', you can scroll down to see all your stats; then tap 'X' at bottom of stats or press button to get out.
