07-29-2020 09:52
07-29-2020 09:52
I have reviewed other posts in the community and see that I am not the only one who has had this issue. It started yesterday, and after reviewing the suggestions of the moderators here I began with the restart.
The first 2-3 times I would get the smiley face after restarting and display would return but only initially, after that it would go blank again. After about 5 restarts my display seemed to come back fine for a few hours but has since gone blank again.
After reviewing several more posts today I tried switching the clock face several times with no luck. I’m also not getting the smiley face anymore upon restarting.
Everything is still synching fine, and I still get vibrations for all my notifications, reminders to move, etc. but my screen just seems to be done for. It’s discouraging as I’ve only had it for 7 months; I had a Fitbit Alta for 5 years prior that I could still likely charge up and use today, it had zero issues.
12:43
07:01
08-03-2020
12:43
07:01
@lexyrae24 It's nice to have you on board!
Let me help you with your Inspire HR screen not working and thank you for troubleshooting this issue. Since the issue persists I suggest you let our Support team know about this. I noticed that you already have a ticket with them so keep working with the team to find a solution.
Let me know how it goes.
12:43
07:01
08-03-2020
12:43
07:01
Best Answer08-03-2020 17:04
08-03-2020 17:04
Hello @AlvaroFitbit and thank you!
Yes, I contacted Support last week and they were wonderful. They were quick to work through some additional troubleshooting before determining that I was eligible for a replacement through my warranty. I was also amazed at how fast the replacement was shipped out. Cannot say enough good things, thank you again!
11:32
07:01
08-11-2020
11:32
07:01
@lexyrae24 thank you for your reply.
Really happy to hear that our Support team assisted you and provided a replacement. Happy that you are back on tracker and resuming your activity tracking with your Inspire HR.
Happy stepping and stay safe!
Best Answer08-15-2020 01:06
08-15-2020 01:06
@AlvaroFitbit Do you think you can help me as well? I've tried to navigate the site every way possible to contact customer support without luck. I have a similar problem. My fitbit inspire was at 58% and I plugged it in to charge then the screen went blank. I checked the site and read the forums and tried to plug it in and hold the tracker button for 15 seconds to restart but nothing happened, no smiley face. I tried this for 3 times and nothing happened. I still see the green light underneath and sometimes while trying to charge there would be a vibrate. However, I am not getting any response in terms of the screen turning back on. Thank you so much. Best,
07:34
07:00
08-24-2020
07:34
07:00
@supermink Thanks for stopping by!
Let me help you with your Inspire HR not working and thank you for troubleshooting this issue. One think I want you to try is, if your tracker is syncing, to change the clock face by following these instructions.
