Inspire HR doesn’t turn on
I tried restarting it, but nothing happened
1 REPLY 1
@AfroDuck Welcome! It's great to see you around!
Let me help you with your Inspire HR not working. Not sure if this may be a display issue or a charging one so try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
Alvaro | Community Moderator
