10-29-2023
01:38
10:10
10-29-2023
01:38
10:10
My Fitbit HR has not compiled any data in 11 days... It is now just a glorified (and fairly useless) watch that doesn't charge properly.
Is this due to the new app?
Is there any way to fix this? (that doesn't involve buying another newer Fitbit? the newer ones are too big).
Best Answer10-30-2023 04:28
10-30-2023 04:28
Hi, @Mel_Black , it sounds like your Fitbit is not syncing properly. As a first step I would recommend logging out of your Fitbit app and then logging back in again. Be sure you know the email address and password associated with your Fitbit. Logging in should force a sync. It is also worth giving your Fitbit a restart. Instructions are here .
If you are still having difficulty syncing your Fitbit, please work carefully through the steps suggested in this help article , except that I would not recommend removing your Fitbit from your account, except as a last resort because removing it can cause further issues if you are unable to add it back.
Good luck! Let us know how it goes.
11-01-2023 18:45
11-01-2023 18:45
My Inspire switched itself to "clip settings" one day. I haven't idea how, but I was able to set it back to "watch settings" and it started tracking again. I don't remember where to find that setting again, but the web page should direct you. Hope that helps
Best Answer11-06-2023 00:51
11-06-2023 00:51
Same for me (inspire HR) since the last android application update (17 october 2023). Tried to uninstall/install the fitbit app. Not working at all
