02-16-2023
23:30
11:46
02-16-2023
23:30
11:46
My inspire HR keeps going on off even if it's full charhed after maybe 20mins of useage it goes and shows that the battery is dead.
Best Answer02-17-2023 01:27
02-17-2023 01:27
Hi @Justin19 That doesn't sound good at all. Have you tried Restarting your tracker? You could also try THIS Help Article on Battery Life. If nothing helps then contact Fitbit Support and hope they can help.
Helen | Western Australia
02-17-2023 02:49
02-17-2023 02:49
Thanks for your response. I just did that hopefully it works well.
