04-02-2019 17:51
04-02-2019 17:51
My Inspire HR just went dead after being fully charged. Tried putting it back on the charger...nothing. Is there a way to restart it?
Best Answer04-03-2019 00:44
04-03-2019 00:44
There is a restart procedure but it requires it to be charging so it may not work:
If that doesn't work then your best bet would be to contact customer support via contact.fitbit.com
04-03-2019 00:44
Best Answer04-03-2019 08:36
04-03-2019 08:36
Thanks! That did work even though it wouldn't vibrate when I put it on the charger.
Best Answer05-11-2019 01:31
05-11-2019 01:31
My inspire HR is dead as well pre ordered before realease day in the UK ...recieved on the 22 march and is dead as well!!!!. I have written to the fitbit no reply yet ...assume I will probably go back to my strang and stable misfit if no help .
Best Answer09-26-2019 10:21
09-26-2019 10:21
Thanks! Worked as described!!!
