Inspire HR is fine, but app and website not working
My Inspire HR is fine, tracking steps and sleep, but when I sync, that data does not transfer to the app or the website.  The website has been wonky for a week now.  Any help??
1 REPLY 1
@lizvocal I hope you are doing fine.
Let me help you with this. Your tracker's data need to sync in order for it to show on the app and website so I suggest you clear the link between your phone and your tracker by doing the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Hope this helps.
Alvaro | Community Moderator
