05-09-2021
08:08
08:22
AlvaroFitbit
05-09-2021
08:08
08:22
AlvaroFitbit
My Fit Bit HR stopped recording sleep data. It also stopped syncing. How do I fix this?
05-10-2021
08:24
08:01
05-10-2021
08:24
08:01
@Lat67 Thanks for joining us!
If your tracker isn't syncing the no data will be transferred to your account, this includes sleep data. You can try the following:
Hope this helps.
05-10-2021 09:45
05-10-2021 09:45
I've been having the same problem this past week. I did all of the troubleshooting steps including replacing my device in the app three days ago. The device synced as it should for a day and stopped again.
05-10-2021 15:53
05-10-2021 15:53
05-15-2021 05:49
05-15-2021 05:49
I had given up trying to fix this because I was pretty sure the problem was with the app. I can't say when, but my Fitbit started syncing and working properly a day or two after I uninstalled and reinstalled the app. I've found, when there is some unexplained, random problem with my Fitbit, it's easier to just wait it out and it will usually fix itself with the next app update or recharge.
