04-29-2020 21:10 - last edited on 05-07-2020 08:25 by AlvaroFitbit
Hello,
My Inspire HR has started to vibrate continuously and will only stop if I hold the button on the side down. It is not vibrating due to notifications, so I don't know what is causing it. I have performed a restart on the device multiple times, but it still is vibrating. Not only is it not better after the resets, it has started to vibrate more often too. Any advice or way to make this go away? Thanks!
05-07-2020 08:39
05-07-2020 08:39
@MaryLS19 Welcome to the Community. Sorry for the delay in my reply.
Let me help you with your Inspire HR vibrating randomly and thank you for troubleshooting this issue. Since the issue persists I suggest you let our Support team know so they can further assist you. I noticed that you already have a ticket with them so keep working with the team to find a solution.
Let me know how it goes.
05-11-2020 07:07
05-11-2020 07:07
I'm having the same problem. I've checked the web for ways to resolve and have restarted it at least 5 times to no avail. Going to try to call support today after reading reply to your message. If you find a fix, will you please post it and I will do the same. Thank-you
05-25-2020 14:03
05-25-2020 14:03
Please share the resolution as mine is doing the same thing! I already uninstalled the app - did the forget this device - reset the device...... All that just to get it to Sync. Now it just buzzes at random times.
05-25-2020 14:07 - last edited on 06-29-2020 18:59 by LiliyaFitbit
I ended up getting a new one issued to me since mine was still covered by warranty.
Sincerely,
05-25-2020 14:17
05-25-2020 14:17
05-28-2020 10:54
05-28-2020 10:54
@tsschmidt2020 @L-Starr Thanks for stopping by! Sorry for the delay in my reply.
@tsschmidt2020 @L-Starr let me help you with your Inspire not working as it should and thank you for troubleshooting this issue. Since the issue persists please reach out to our Support team so they can further assist you. I noticed that you already have tickets with Support so keep working with the team to find a solution.
@MaryLS19 happy to hear that Support replaced your device.
Keep me posted.
05-28-2020 12:34
05-28-2020 12:34
They did not replace it and did not tell me how to stop the random buzzing. The “help” was awe full!
