Inspire HR locks up when using countdown requiring reboot with charger
My Inspire HR locks up and will not return to anything other than the point where I started the countdown or the main list of hrs and minutes. Stroking, swiping, pressing "the button" will not get you back to your watch. The only thing to do is to reset the watch using the power adapter. Design defect?
2 REPLIES 2
That is odd @qaps . Mine seems to work fine. Have you tried restarting your Inspire a few times? If not, give it a try. Come back here if it doesnt resolve the issue.
Restart your tracker
Community Council Member
Helen | Western Australia
Hi NelliG/Space Racer/Helen I,
Thanks for the suggestion. I had already tried the multiple reset thing, but figured this morning, why not? one more time. It worked! I did a few more trials and discovered that unless the press on the button is very, very short, it will still lock up. The button press has to be just a tap or the endless loop thing kicks in on mine.
qaps
