09-09-2019 12:04
09-09-2019 12:04
While on the treadmill the step counter goes up and a little after 4000 steps it restarts at about 3700. Over and over. Help!
09-10-2019 09:08
09-10-2019 09:08
Hi @NewbieMD, nice to see you around. Welcome to our community.
Thanks for letting me know the issues that you're having with your Inspire HR. This is not a normal behavior. Please restart your Fitbit with these instructions: How do I restart my Fitbit device? Then give it a try one more time. Also try with different exercises to make sure it is working again.
Give it a try and keep me posted.
09-10-2019
09:23
14:29
YojanaFitbit
09-10-2019
09:23
14:29
YojanaFitbit
Thanks. Just fyi the link to the restart instructions doesn’t go directly. You have to basically look in the manual?
Mark D
Moderator edit: Removed personal information
09-11-2019 14:32
09-11-2019 14:32
Hi @NewbieMD, thanks for getting back and for letting me know the issues that you had with the restart instructions.
You can also check the information here: How accurate are Fitbit devices?
Let me know if you need more help.
