06-19-2019 07:18
06-19-2019 07:18
I know this has been a issue from previous posts, however I am not sure if there is a solution.
This morning I did a one hour intense work out (Group Power) lots of weights and cardio. It tracked 57 active minutes however did not recognize it as an exercise.
I have tried restarting my inspire, logging out the app and turning my bluetooth on and off (suggestions from another user) and nothing.
Anything else I could try? Thanks! 🙂
Best Answer06-21-2019 11:25 - edited 06-21-2019 11:34
Hope you’re having an amazing time on the Forums @NicoleLaunders, I’m really glad that you’ve joined us. Welcome aboard! My apologies for the delay.
Thanks for sharing your inquiry here and for the information that you can see on your Dashboard. You have done a great job with the steps that you've performed to try to solve the issues with cardio workouts.
SmartTrack recognizes and records select exercises to ensure you get credit for your most active moments of the day. This feature only recognizes workouts or activities that have continuous, high-movement activity.
Some of the exercises SmartTrack recognizes are:
SmartTrack also recognizes two general categories:
I'd consider tracking your weight lifting exercises directly on your Inspire HR with the option "Weights". Please note that many exercises such as weight lifting cause you to bend your wrist frequently, which could interfere with the heart-rate signal if the watch is lower on your wrist.
When doing weight lifting, your wrist muscles may flex in such a way that the band tightens and loosens during exercise. Try relaxing your wrist and staying still briefly (about 10 seconds), after which you should see an accurate heart-rate reading. Note that your device will still provide accurate calorie burn readings during these types of exercise by analyzing your heart rate trends over the course of the workout.
If you have questions about this let me know.
I'll be around.
I'll be around.
01-18-2020 14:32
01-18-2020 14:32
Similar to the previous post, I did an intense boxing session for almost an hour . Howeve , it only shows that I burned 260 calories whereas my friend who has Alta model has 1000+ calories burned. I have an inspire HR model. Annoyed. Help
