Inspire HR not charging, quick view issues, display goes black
I have to say I am disappointed in the Inspire HR. After having a Charge and Blaze I wanted to stick with fitbit. My Blaze just stopped charging, and I liked the smaller face plus didn't want to go to the Versa so thought the Inspire HR would be close to the Charge. But The Inspire does not work as well.
1. It is not sensitive to arm movement to display clock, I'm always having to use a second hand to touch it to see the time or notification. But when I touch it to see the notification it clears the darn notification, so it's useless.
2. The charging situation is ridiculous, I am so angry at it. It does not charge unless balanced perfectly. Even bought another one from Amazon and same exact issue. Dumb!! How dumb of a design.
3. Now it goes black and will not show the display intermittently.
 I am shocked Fitbit made such a terrible watch.
1 REPLY 1
@MG12345 A warm welcome to our Community!
Let me help you with your Inspire HR not charging and display issues. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
The restart should also help with the quick view and display issues.
Let me know how it goes.
Alvaro | Community Moderator
