06-16-2019
12:49
05:51
06-16-2019
12:49
05:51
My HR is not showing up no matter what I do. I have followed the steps on the Help page to make sure the HR is on, which it is. I have restarted my Fitbit. I made sure all updates have been done. I made sure it was snug on my wrist. Everything looks good and I’ve done all I can, I think, but the HR is not working. Anyone have any other tips or tricks?
Best Answer08-09-2020 05:59
08-09-2020 05:59
Thank you. The problem is solved.
Best Answer08-09-2020 07:48
08-09-2020 07:48
not finding settings on my inspire hr. on the app-as you suggest- where do I find the acct? I am sure that like me, others do not know all the tech details used freely on this forum. Thanks
Best Answer08-11-2020 18:35
08-11-2020 18:35
Maybe you dont have a Inspire HR. Mine is Inspire (theoriginal) and it aparently is dosent come with a heart rate monitor. Its sad though. I lost my receipt and trew away the packaging because I WANTED a heart rate monitor. I hope that maybe they could fix in the future in a new update or something...
Best Answer08-12-2020 03:25
08-12-2020 03:25
Best Answer10-17-2020 19:16
10-17-2020 19:16
Thank you!!
Best Answer10-23-2020 13:18
10-23-2020 13:18
Perfection. Thank you!
Best Answer12-01-2020 19:01
12-01-2020 19:01
WOW I spent 25 mins trying all these wrong things. THANK YOU!
Best Answer12-05-2020 05:06
12-05-2020 05:06
This was the best response! Thank you it work. Knowing what direction to scroll on tracker makes a difference! Have a great day!
Best Answer12-11-2020 19:33
12-11-2020 19:33
My Inspire Fitbit won’t display my heart rate either. I’ve dine all the corrections steps, but it still doesn’t work. I’m about done with this device and it’s only a week old. So disappointed.
Best Answer01-01-2021 14:42
01-01-2021 14:42
Found another solution elsewhere
My symptoms:
-Device: Inspire HR 2
-No HR (displayed as -- in main screen)
-HR mode is ON
-I'm not dead
My solution:
-Long-press your buttons to bring up the screen lock/swim mode menu
-Scroll to "position"
-Mine had gotten switched to "on clip" instead of "on wrist". I guess if it's "on clip" and thus nowhere near your skin it's not going to be running the optical HR sensor.
User experience suggestion for fitbit:
-When a user sets HR to ON, have a warning saying "your fitbit is set to 'clip' mode, do you want to change it to 'wrist' mode?"
-When a user sets position to "clip", have a warning saying "this will disable HR. are you sure?" and don't proceed without validation
-In case they accidentally set it to clip anyway (I suspect I was just really sweaty and accidentally set clip mode), maybe instead of "--" for HR, put "on clip"
01-16-2021 10:12
01-16-2021 10:12
I'm trying this but have no heart rate option...just heart zone. So frustrating!
Best Answer03-21-2021 13:19
03-21-2021 13:19
I have the Inspire 2 and when I checked, it was already on. It worked yesterday
Best Answer04-20-2021 07:14
04-20-2021 07:14
I do not see HR in my options in either the settings of the fitbit or the app. I am so frustrated.
Best Answer06-13-2021 10:26
06-13-2021 10:26
Hello
i JUST got my new Fitbit and seem to be having the same trouble with the heart rate for my inspire hr; I have used all your suggestions for fixing it but NOTHING Is working!!!! HELP
Best Answer04-01-2022 21:55
04-01-2022 21:55
Hit the button on the side. Scroll down to on clip/on wrist. Make sure it says on wrist. If it says on clip the HR is automatically turned off
Best Answer09-23-2022 14:50
09-23-2022 14:50
Hello there!
I had this issue with my Fitbit, I think it started after last charging. The heart rate is gone, same with the green light. I tried the following:
- Switched the heart rate in the settings off and back on (nothing happens even if it is on all the time)
- Reeboting the device
- Connecting to charger again.
Still, no luck 😞 please help!
Best Answer09-24-2022 06:53
09-24-2022 06:53
Mine worked fine until last night, had it for more than 2 years.
Also made sure the heart rate setting was turned on and have rebooted.
Please help
