10-15-2019
03:28
09:19
AlvaroFitbit
10-15-2019
03:28
09:19
AlvaroFitbit
Can’t receive any messages from my watch
09:52
06:10
10-16-2019
09:52
06:10
@antahero84 Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your notifications. Which phone are you using? Is it compatible? You can try the following:
Let me know how it goes.
Best Answer10-16-2019 15:11
10-16-2019 15:11
@antahero84 I have found that the most common reason if compatibility and permissions are not an issue is the DND feature. If you have your phone on silent, you have to check off that you want the app to still buzz your tracker when you get a message. Also, make sure that if it is texting, you have the right app checked off.
Elena | Pennsylvania
