11-16-2020 17:57
11-16-2020 17:57
It logged Friday night, the first night I wore it to bed. It hasn't logged any nights since, though. There's no sleep data collected whatsoever. I went to the page about getting a better analysis for a Sleep Score. I tried those tips, and nothing changed. I have all the right settings otherwise! Help please!
Best Answer11-16-2020 23:08
11-16-2020 23:08
I have the same problem. Worked fine from early March and suddenly stopped tracking things like sleep and time spent stationary or active. I have followed all available tips, including rebooting my device but still nothing.
11-18-2020 08:54
11-18-2020 08:54
Welcome to the Fitbit Community, @NoveTheGreat and @LouLouOtis. I'll be glad to assist with your sleep record inquiry.
Since your Inspire HR isn't registering your sleep, I recommend trying the following:
If your trackers are registering your sleep but not providing you with sleep stages, take into consideration the steps in the help article Why don't I see sleep stages today?. I also suggest checking if your Fitbit app is updated.
Let me know the outcome.
11-18-2020 10:53
11-18-2020 10:53
Hi. I have tried steps 1 and 2 again. I had already done both of these prior to logging the problem. I have erratic sleep patterns and tracking the time I spend asleep, restless or awake is a very important feature for me. I have previously tried to manually start the sleep tracker when I go to bed but it just logs sleep as if I have been asleep from when I started the tracker manually and then stopped it. This is an unsatisfactory solution to the fault on my device when I know I have been awake several times during the night, sometimes for prolonged periods. It also does not track time spent stationary or active, which might suggest a fault with the sensor which normally tracks all these things. In my view the device needs to be repaired or replaced. Can you advise how I would proceed please?
Best Answer11-20-2020 20:01
11-20-2020 20:01
I already sleep with it on my non-dominant hand. Should I try swapping to my dominant?
