11-28-2020 16:05
11-28-2020 16:05
Today I used my Fitbit to track my swim for the first time. Prior to this I’ve manually logged my swim on the app.
The device was definitely working when swimming. But after ending the session the swim hasn’t logged on the app.
I’ve used the reset option when the device is connected to the charger, as recommended by live chat, but it didn’t work. Live chat seems to be offline now.
Can you help me to get my swims to sync.
Best Answer11-30-2020 03:59
11-30-2020 03:59
Hi @FoMozza , Restarting your device wont get it to sync an activity it failed to record. Hopefully it will track it next time though. Just checking - when you swim, are you swimming a recognised stroke (overarm, breaststroke, backstroke or butterfly)?
Helen | Western Australia
Best Answer11-30-2020 11:07
11-30-2020 11:07
Best Answer11-30-2020 15:52
11-30-2020 15:52
Breaststroke is apparently harder for trackers to work out than the other strokes, but having said that, my fitbits always pick up my breaststroke. It may be to do with how you do it (I'm guessing here). If if still doesnt pick it up on Friday, try altering your arm movements in the breaststroke to make the movements bigger or more defined (for example if you have a slow smooth arm motion, try doing a stronger, more definite PULL motion). Good luck, and go back to Support if you co tinue to have problems.
Best Answer11-30-2020 16:29
11-30-2020 16:29
